figured id start a build thread since stuffs getting done
Old 07-30-2012, 11:19 PM
  #51
2doorfury's Avatar
Don't forget the ground on the back of the block when you put the heads on... LOL
im really glad you brought this up, i was looking at the grounds, theres the strap from firewall to engine, then theres one on left side of the engine harness and one on right..does the right side harness one and ground strap use the same bolt/place to ground??
Old 08-01-2012, 07:56 AM
  #52
2doorfury's Avatar
bump, anyone have a answer for my question above??
Old 08-01-2012, 02:31 PM
  #53
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
You should be able to just bolt it to the block that's what I did with all the factory grounds on my truck when I did the motor swap
Old 08-01-2012, 04:37 PM
  #54
Custm2500's Rude Friend
1FastBrick's Avatar
I believe they all go to one spot as well. I have not had time to look.
Old 08-01-2012, 11:39 PM
  #55
2doorfury's Avatar
ok. im sure as long as there all grounded somewhere, itll work.
Old 08-10-2012, 11:14 PM
  #56
2doorfury's Avatar
bought some pushrods from a member on here. i see a first start in the VERY near future. (as in next weekend)
Old 08-11-2012, 06:07 AM
  #57
Hivelocit's Avatar
Did you use a PR length checker or just wing it? Once I changed my lifters over to LS7's and heads shaved a bit figured better safe then sorry!
Old 08-11-2012, 07:56 AM
  #58
2doorfury's Avatar
yes, i used the pr length checker. came up with 7.325. thats with .050'' preload. i was told .075'' preload is best. so i went with a 7.35 pushrod. hopefully they workout good and i dont get any lifter noise.
Old 08-11-2012, 08:50 AM
  #59
13 Second Truck Club
LS1FREEK's Avatar
Nice, I'm in for results on the 6.0 swap, I've done 4 so far! LOL I've loved every one too!! VERY worth the work.
Old 08-11-2012, 09:01 AM
  #60
2doorfury's Avatar
i hope everything goes smooth. im pumped to get this thing fired up. im dying to hear what this sounds like with the decently sized cam i went with..specially with 110lsa. should sound pretty rowdy!! lol
Quick Reply: figured id start a build thread since stuffs getting done
