Finally! Turbo Build! Huron Speed/On3
Old 07-14-2014 | 08:52 PM
oakley6575's Avatar
I see I see. That sucks man. I had a similar experience when I put my trick log on. The flange holes were misaligned and wouldn't bolt up to the head. Little bit of a set back but I redrilled it and got it to line up.
Is Huron going to send you a new one or do they have to make and whole new log?
Old 07-15-2014 | 05:18 AM
AJII's Avatar
Well, sometimes you just can't stop a man that's been working on a truck all day and REALLY REALLY wants to see a turbo manifold bolted up.
Sooooo....got a grinder and got to work. Ended up having to take out more than I thought I would have to but once you start, there's not really any going back.
A man and his grinder. It's a beautiful thing
Getting there...Name:  A52BD687-92FE-49AC-BF28-129B8D4AC185.jpg
There!
But it was all worth it
Plenty of clearance around the plug wires
Old 07-15-2014 | 07:58 AM
silver-mod-o's Avatar
Hunt&Fisherator
so what all did you end up grinding??
Are they still going to send you revised parts?
Old 07-15-2014 | 09:29 AM
AJII's Avatar
We reached a fair agreement on some compensation for what I had to do. Waiting for the WG to get here to make sure it fits as intended, but doesn't look like it should be a problem (but this is coming from a guy who has never actually seen a WG before )
Here's what ended up having to be cut. The mount still has tons of meat left so I'm not concerned. And it's covered so you can't tell it at all, especially once it's painted. And I'd honestly rather have this problem than the plug wires laying on the log or something.
Old 07-15-2014 | 08:01 PM
Go5.3tt06's Avatar
where did u got oil catch can I want one. How to hook up?
Old 07-15-2014 | 08:05 PM
timmay208's Avatar
even with that grinding when the motor moves it looks like it still may hit
Old 07-15-2014 | 10:36 PM
98tdi's Avatar
I was thinking the same thing
Old 07-15-2014 | 10:51 PM
Atomic's Avatar
I have a gauge for that
Uh oh! Prepare for broken parts! Good luck bud!
Old 07-15-2014 | 11:20 PM
GMCtrk's Avatar
Weld up the stock motor mounts, problem solved. But yeah, that's definitely going to bang on the frame under power.
Old 07-16-2014 | 02:17 AM
AJII's Avatar
Got it from ws6store. I have it pass valve cover to can, can to intake. and a one way valve in the line to the intake.
What you cant see is that everything slopes downward behind where I grinded and it shouldn't hit. But if it does, it'll clearance itself right?
Don't say that! I'm outta money now!
