Finally! Turbo Build! Huron Speed/On3
Old 11-16-2014 | 06:45 PM
  #61
AJII's Avatar
Originally Posted by mdwatts11
That could've turned out really bad! At least you were able to salvage the motor. Were you able to find a piston?
Not yet. Turns out 2005..what I have...Lq4s are unique. They have floating pins and regular dished pistons. Earlier ones have pressed pins. And later ones have floating pins but dished pistons with valve reliefs.
Old 11-16-2014 | 07:01 PM
  #62
AJII's Avatar
Originally Posted by Atomic
Thatll do it!
I recommend replacing all the rings and doing a clean up hone before you install them
This may be the most debated thing I've ever researched on LS1tech. haha
Half say if you put the same piston and same rings back in the same hole, you'll be fine. Others say without a hone, you'll have an oil burning machine.
But don't people open up the gap on rings all the time and run the engine without a hone? Or is the internet lying again?
Old 11-16-2014 | 08:29 PM
  #63
Noah Burns's Avatar
5 & 7 is pretty typical. had the same thing happen on my z28, as I slid the piston up out of the block the bottom stayed in… totally smoked the ring land right off the piston.
I agree with Atomic, buy some good rings and hit it with a hone. You'll be glad you did.
Old 11-16-2014 | 08:31 PM
  #64
AJII's Avatar
What are good brands of rings? GM only?
Old 11-17-2014 | 05:03 AM
  #65
Noah Burns's Avatar
I'd go with a good aftermarket set actually, Hell-Fire would probably be my choice.
Old 11-18-2014 | 08:01 PM
  #66
I think your gonna like that turbo, when you actually get to enjoy it. I made a few hits at 15.5psi with mine this evening. Hit a 0-60 in 4.0sec spinning in 4hi.
Old 11-19-2014 | 02:16 AM
  #67
Iconic Motorsports
your already there put some forged pistons and rods in there, hone it. safe for boost.
Old 11-19-2014 | 07:00 PM
  #68
Noah Burns's Avatar
^^^ that!!
atleast pistons for sure
thunder550
10-08-2015 05:53 PM
USMCvet0311
08-14-2015 11:28 PM
slowlsx
08-04-2015 11:04 PM
Ls3silverado
07-31-2015 05:22 PM
Cowboy17
07-09-2015 07:18 PM
