Finaly putting her togather.
#44
you will between 12.5 and 12.75 to 1 depending on gasket thickness. I would run the L92 or LS9 headgaskets. I ran Diamond pop-ups in my 370 at 11.5 to 1 with L92's as a DD motor. I couldn't run more than 26* total timing. NA it made 504whp. I sure do miss that motor..
#45
LS9 stock replacement head gaskets?
Will this gasket work?
http://www.summitracing.com/parts/NA...0046/?rtype=10
I got stock LS1 gaskets not thinking about the larger bore. My bore is 4.030 and the ones I posted is 4.080 bore.
If they won't can someone point me to the correct GM performance headgasket for my aplication? Eveyone keeps saying just use GM performance gaskets but I can't find one for my exact bore size.
How about this gasket. It is a 4.020 bore?
http://www.summitracing.com/parts/NAL-12589227/
#48
GM Performance 12610046 - GM Performance Composition Head Gaskets - Overview - SummitRacing.com
GM Performance 12589227 - GM Performance Composition Head Gaskets - Overview - SummitRacing.com
