Forged 370 coming together.
#44
Originally Posted by Spoolin
If only that were true I'm sure that would make your day. You've had your eye on me from day one...put some ice on your crotch and go back to watching 9 yr old boy **** in your office. I haven't said anything about what you were doing the last time I came by your shop...door closed, all phones on busy, and that guilty look when you finally came down with that sticky handshake.
LMAO!
#48
Originally Posted by dhpro
Sweet lookin setup! Custom bling always sets off a build...how long before it fires up?
Richards keeping an eye on it but he's got his own buissness to run.
I'll throw out an update later. But it's a real PITA.
#49
PITA is right! My guys are pretty good now thats its in their shop, but fortunately they're only 5mins away, so I stop by every fri or sat and send reg e-mails looking for pix and updates...they know I'm renting a car too, so if it drags on too long I'll start taking that cost out of their hides....R/
#50
Well despite the hang-ups and aggrevation w/ the shop I'm working with, the guy is doing some absolutely great freaking work, which in the end is what matters. Engine and tranny are in, exhaust is all reworked and redone. No more silicone and band clamps for me! Their weld work is awesome, nice clean welds, ground them down to ensure proper welds with no leaks. They fabbed it up on the truck first before taking it off to get it heat coated. Last things to be finished up is the Fuel system and piping into the TB.
Here's a couple pics.
Re-installed my spare flowmaster (yeah i know but I had it laying around) just to deaden some of the whistle while DD'ing.
View of "the mess". Turbo charger + waste gate + electric cut-out + dump + charge pipes and exhaust. I realize the cut-out isn't gonna do much for performance but it'll make it a little louder and more importantly should help make the pressure difference across the turbine greater when it's opened.
Back side of "the mess". Electic cut-out is Doug's. I'll also be drilling a small hole at the lowest part of the Hot side just before the turbo to drain and water.
Hot side before it's all sent off to get a triple coat, I might wrap it after the coats. I've heard of plumbing rusting out with wraps so I hope with the three coats in between the steel and any water that will get trapped by the wrap I'll be safe...for a while. I'm just trying to retain as much heat as I can for a quicker spool.
Cross over and Y.
Long tubes and the underside of the FLT 80E-5. Sweet jesus I might get it all painted black!! What's wrong with me??
Engine in and fuel rails in, just waiting for intake plumbing. Trying to find a way to make an elbow work. Right now it's hitting the top of the cowl/firewall...any suggestions? Going to re-work + weld the charge side in a few months after I break the engine in a bit, get rid of as many twists and turns as I can, similar to trtturbo's and Wilde Racing's among others.
Yup, I'm one of those ********...just another heavy *** thing to take off for track days. Should be fun on the street though.
Cross over and Y.
