Front mount swap
Old 01-03-2011, 05:33 PM
  #41
Slowest turbo build ever!
black00chev's Avatar
Just curious but couldn't you clock the compressor housing 180* so its pointing towards the left side of the engine up top and get rid of that 180* bend in the pipe? Once you go SD like you said, wont have to worry about relocating the MAF.
Sounds awesome
Old 01-03-2011, 06:57 PM
  #42
charcold-bowtie's Avatar
Just coming back to make the point of...
Does the truck feel stronger driving, even when outta boost?
Old 01-03-2011, 08:24 PM
  #43
Mod with training wheels
smokeshow's Avatar
Originally Posted by OnyxSilveradoSS
looks good. how does it spool? should have asked for before and after tests
Spools pretty nicely. I posted a video of it in my last post.
I could, but then it would run right into the intake pipe from the intercooler to the throttle body. The turbo sits pretty high...T6s are big turbos
No, it feels exactly the same out of boost. It feels weaker from an idle dig because the 5.3 is powerless to spin the tires with the 80e and 3.73s. Cruising around in vacuum, it still doesn't make power until the gauge swings past 0.
Old 01-03-2011, 10:42 PM
  #44
Stoichiometric's Avatar
Originally Posted by smokeshow
I blew the MAF off twice yesterday....getting a little annoying! I am scared to crank it down since its just plastic.
You could add tie bars across the MAF to hold things together.
Old 01-04-2011, 02:06 AM
  #45
smokeshow's Avatar
Thats what I was thinking. Blew it off again tonight. I take it adding tie bars isn't uncommon in boosted MAF setups?
Old 01-04-2011, 02:24 AM
  #46
SincalT/A's Avatar
I went through the same problem with the maf blowing off.I ended up driving small screws in to it to help the coupler stay.Its has seen over 20#'s without blowing off.Make sure there is no other forces yanking on it like when the engine shifts at wot.
Old 01-04-2011, 11:10 AM
  #47
kbracing96's Avatar
Hair spray Take the couples apart, clean them up really good, then put some hair spray on everything and put it back together. The hair spray acts like a mild glue and keeps it from blowing a part.
Looks GREAT!!
Old 01-04-2011, 08:21 PM
  #48
11 sec. Truck Mod
TIM Z's Avatar
x2 hair spray works good.
Also you can get some Duramax intercooler couplers/ clamps,
I know there are good for 40 psi without coming off LOL
Glad you got her running, enjoy.
Old 01-04-2011, 09:53 PM
  #49
JakeBrakeIH's Avatar
Looks GREAT!!
Kyle told me bout this too and it worked excellent. Kinda funny going to buy hair spray for your truck
Old 01-04-2011, 10:02 PM
  #50
smokeshow's Avatar
Bout to go test it out. Got to do some WOT tuning now, so its gonna see some pressure I told my gf that I needed her help with my truck and she was way excited to lend me some hairspray to fix it
Quick Reply: Front mount swap
