Gray Ghost turbo 427 LSX build
Old 05-06-2013, 10:44 PM
  #161
Gray Ghost Silverado's Avatar
Originally Posted by idahoblkss
i ran into the same problem i had to get a earl fitting and clearance the plastic on the back of the alt a lil bit. earl fitting on right ...
That's pretty trick also. How much room did you have after you finished?
Old 05-06-2013, 10:54 PM
  #162
oakley6575's Avatar
I ran into this when I tried to install my FAST intake. I'm interested to see how yours turns out. Keep up the good work
Old 05-08-2013, 02:50 PM
  #163
The rear feed fittings came out awesome though!
Old 05-08-2013, 03:02 PM
  #164
oakley6575's Avatar
How are you routing the fuel flow? Both feeds from the rear and then dual returns up front?
Old 05-08-2013, 03:09 PM
  #165
That's correct. I work from back to front because my front fittings are going to be a bit more restrictive than the rears and I'd rather use those after the injectors. The fronts 90 out of the rails and pass back beneath the intake manifold and then run to both sides of the regulator. Then into the return line
Old 05-08-2013, 03:22 PM
  #166
04Hall's Avatar
Man that is a good looking setup! I envy you.
Old 05-08-2013, 03:28 PM
  #167
Thanks! Can't wait until my new valve covers and P-Rod length checkers are here. This motor looks like it's going to require about an 8.3" p-rod
Old 05-08-2013, 03:31 PM
  #168
I have been slow on making progress because I have been helping Bob set up a vehicle lift in the shop. Man it's going to make my life easy!
Old 05-08-2013, 04:06 PM
  #169
04Hall's Avatar
Can't wait to see some numbers! I'm pretty sure you could put that in a heavy *** school bus and run 10s all day lol
Old 05-08-2013, 04:10 PM
  #170
I have a gauge for that
Atomic's Avatar
The front fitting I used is the fragola fitting that has the -8an o ring fitting already on it.
Quick Reply: Gray Ghost turbo 427 LSX build
