Home Grown Boost and More
Old 06-20-2012, 08:37 PM
  #211
Slowest turbo build ever!
black00chev's Avatar
I would call Summit tomorrow and talk to someone! Souds like you have checked everything out that it could be. Leaves me to believe the part is deffective.
Old 06-21-2012, 02:43 PM
  #212
Un-Registered User
mcfarlnd's Avatar
May be a silly question but, you are still holding the brake pedal down after you engage the lock right? You are basically using the line lock as a "off" switch for the rear brakes. It won't hold your pressure to the fronts.
Old 06-21-2012, 04:07 PM
  #213
03RCSB's Avatar
I chocked the front, put the rear up in the air and put it in drive, the wheels spin. Engage the line lock which should now be blocking pressure to the rear. Hit the brakes, the rear stops spinning.
Just for giggles, I press the brakes so the rear isnt spinning, engage the line lock which should now be holding the wheels when I let off the pedal. I let off the pedal and they spin.
Acts like the line lock isnt there.
Old 06-21-2012, 04:26 PM
  #214
I have a gauge for that
Atomic's Avatar
Might be a dumb question but you put it on the main line going back to the tee, right? Not one of the individual brake lines...
I noticed when I have the lock engaged the pedal is MUCH firmer.
Old 06-21-2012, 04:29 PM
  #215
03RCSB's Avatar
Yup, its in the same place yours is. On the frame rail right before the rubber line. How loud is yours? I can hear mine click but it sounds kind of weak.
Edit; should also mention I only hear the click when I turn it on, not off.
Old 06-24-2012, 04:10 PM
  #216
03RCSB's Avatar
80e swap is underway. Had my buddy stop by and help out which made this move pretty quick without any real problems. I work at a snails pace compared to him.
old 4l60e out and next to the new 80e
New flex plate bolted up to the engine
Crossmember modified and painted
Trans in (The pictured yoke is not the yoke being used. Only in there to keep crap out of the trans until the shaft goes in.)
Only things left are:
-Wire up the trans
-Run the new cooler lines
-Put the driveshaft together and shorten if needed
Dont really see anything holding this up other than the shaft being too long. If that turns out to be ok I'm hoping to get back on the road next weekend.
Old 06-24-2012, 06:33 PM
  #217
MASS seller approved
mitchellmade's Avatar
Nice , want to build another 80e? Just joking
Old 06-24-2012, 07:56 PM
  #218
03RCSB's Avatar
Are you going to be rebuilding the one for the AWD rcsb?
Old 06-24-2012, 09:08 PM
  #219
13 Second Truck Club
DV2000NJ's Avatar
Nice! Cross member looks good.
You planning any trips to the track once everything is all buttoned up?
Old 06-24-2012, 09:32 PM
  #220
03RCSB's Avatar
Thanks, I would like to track it a few times but its mainly just a weekend toy. At 12psi if I can get deep into the 12s on street tires and 20s I'd be stoked.
Quick Reply: Home Grown Boost and More
