I can't fabricate?
#151
I know you were being mostly a smart *** but your example(minus the ice part) helps the idea that the rears may stay on the ground.
#153
If you notice they include that in the rules. Mostly to keep dragsters and super fast CHUTE cars out. But is is there for a reason.
#156
PT's Slowest Truck
There's more to it than just friction man, the vehicle needs to stay under control, have the proper center of gravity, the correct suspension geometry, etc.
Over-simplifying the throttle body is one thing, please don't take the vehicle's braking system in that direction also...
#157
That is a street race. The vehical has to be street legal or pass it off that it is. I am sure it has to have plates and lights too. That is part of a street class.
#159
I'm sure someone here can find that calculation for you. What are you planning on runnning as rear brakes I would imagine converting to at least a disc? Also what size rear tire. Both are a very important factor. I think to get the correct amount of fiction your going to need a very large wide tire. Also your suspension has to be dead on or else it will wheel hop as you try to brake and the friction increases. Your most obvious downfall of this idea is the weight of your truck all together. I say just leave the brakes as they are and concentrate on removing weight else were on the truck. Ever consider fiber glass body panels or deleting things like a/c power steering or other things that don't sacrifice yours or others safety?
