I can't fabricate?
I am not bragging that I am a master fabricator. The point of this thread is the fact that wile every measurement isn't perfect, and every weld isn't "certifiable", I built a 4 link and it works perfectly. Obviously that means I can measure, and square up an axle in my truck.
Some people constantly talk about how my truck is a death trap and they have nothing to back it up with. Because I posted a picture with a tarp not tightly stretched on my bed due to my original plan not being enough to hold it.? Because I set my side pipes on a jack stand and a foot of the lift to get a quick idea how they will look? That is the point of this. Most of they "hack" slinging is based on incorrect information.
P.S. I got a PM the other day that basically said "My bed and cab look just like yours... but my truck has never been touched. What do you think the issue is?" I have seen at least 5 trucks on the road just like mine with the can slightly lower then the bed. I am fairly confident that the rubber cab mounts are worn after 10 years and 240,000+ miles therefore the cab is sagging. The bed on the other hand is hard mounted so there is no sagging. The bed misalignment has nothing to do with my skills especially because the factory bed was the same way. Yet I get **** on by some ignorant members because somehow i screwed up in my fabricating by drilling some holes and adding some tabs to the factory frame.
I clean my welding surface fairly well. Sometime I could do a better job but I generaly have perfectly clean metal in my area and try to clean back around a 1/4 of an inch.
I will say those look like good welds for a MIG. I use a MIG for all of my suspension pieces, and they are plenty strong. Your quality is good for that type of work. I have seen a lot of people comment on welds that have never welded. People like the nice ripple of a tig welder, and too often just assume because it has that that the weld is great. I have seen bad welds with the nice ripple, and great welds without it. As far as making a TB, that work isn't in the same class. People bash you because you think you can make a TB, and talk like it is a simple valve. I know it is a valve, and I know that is the main function, but everyone else can see the big picture and you just plain and simply can't.
Hunt&Fisherator
Dude.... You have totally missed any point that anyone made in that TB thread. The problem is, you post all these "in progress" pics and never anything finished, or that turns out looking right.
I still maintain my position that there's lots of things that you don't think out and that's where the criticism comes from.
-they sell 4-link kits so any home builder with much knowledge at all can put one together. Ever wondered why they don't sell DIY throttle body kits?
![hmm](https://www.performancetrucks.net/forums/images/smilies/hmm.gif)
Tin Foil Hat Wearin' Fool
