Lets Try This Again: 410-PT88-80e
#110
If I have issues I have about 20ft of that 10ga wiring from racetronics that is fuel rated, so I will use that...
Here is the description of the wire.
This Summit® SXL primary electrical wire is a cross-linked polyethylene thermoplastic designed for use in engine compartments. It is rated for use of 50 V or less, has a temperature rating of 257 degrees F, and resists the abrasion, oil, and gas found in high-heat applications. Summit® SXL primary electrical wire meets SAE J1128 specifications, so it's the perfect choice for your electrical system needs.
