Lets Try This Again: 410-PT88-80e
Old 12-16-2010, 05:24 PM
  #101
I have a gauge for that
Atomic's Avatar
Old 12-16-2010, 08:01 PM
  #102
MikeGyver's Avatar
That is so..., effing..., hot.
Old 12-17-2010, 01:04 AM
  #103
GFYS and STFU
Spoolin's Avatar
Can you take some better pics of how you wired both pumps? I'm gonna be doing that next week as well and just wanna see how you did it out of curiosity.
Old 12-17-2010, 01:19 AM
  #104
Atomic's Avatar
I have some in my other thread about the fuel style conversion. It's basically 10ga power wire to each and a single 10ga ground for both, so 3 wires total
Old 12-17-2010, 01:46 AM
  #105
Formerly darynC-10/23/10
Daryn's Avatar
i see you have the submersible fuel line.. but do you have the special wire for fuel? regular wire will not hold up to it for long, it will get dissolved
Old 12-17-2010, 01:55 AM
  #106
GFYS and STFU
Spoolin's Avatar
What kinda wire is needed?
Old 12-17-2010, 02:51 AM
  #107
Daryn's Avatar
PTFE wire is the preferred wire but you can get away with polyethylene coated too... pvc is a big no no!
Old 12-17-2010, 09:52 AM
  #108
Atomic's Avatar
I took a sample of it and let it sit in a thing of gas for a while and it still looked good, so I guess we will see. Its some of the high quality stuff from summit.
Old 12-17-2010, 09:56 AM
  #109
GFYS and STFU
Spoolin's Avatar
Did you run a current through the wire while you let it sit in the gas? That changes everything mang!!
Old 12-17-2010, 09:58 AM
  #110
Atomic's Avatar
If I have issues I have about 20ft of that 10ga wiring from racetronics that is fuel rated, so I will use that...
Here is the description of the wire.
This Summit® SXL primary electrical wire is a cross-linked polyethylene thermoplastic designed for use in engine compartments. It is rated for use of 50 V or less, has a temperature rating of 257 degrees F, and resists the abrasion, oil, and gas found in high-heat applications. Summit® SXL primary electrical wire meets SAE J1128 specifications, so it's the perfect choice for your electrical system needs.
Quick Reply: Lets Try This Again: 410-PT88-80e
