Lets Try This Again: 410-PT88-80e
#242
Those measurements are with my PI converter and TCI flexplate. I’m not saying it’s identical to yours, but does stand a good chance of it, assuming you still have a PI converter as well. If you switched to another brand, there is no telling what length you will need for proper engagement.
#247
Good news, got it running again today. I ended up using some 20mm bolts and shimmed the converter 2mm since it was at the upper limit of allowed separation from the pump, also put a dab of blue loctite on the bolts. A few turns with a thread tap cleaned up that one hole enough to get the bolt going. I drove around for a while, then took the cover back off and retightened everything just to make sure.
I also figured out what that horrible scratching noise was...appearently there was a clearence issue with the inspection cover...good thing its soft metal I suppose... I dremeled some more away just in case.
The little chunks in the inspection cover is actually a piece of the oil pan that a bolt hit. If you look directly behind the bolt in this picture you can see where it broke off.
So far I feel like ive gotten really lucky...
Oh and here is my finished exhaust...I think I may try to find a stock duramax muffler to put there since its still louder than I would like with the two magnaflows.
