Lets Try This Again: 410-PT88-80e
#342
Im sending my injectors off to be cleaned and tested, to see if that was in fact the problem. Hopefully I will have the 5.3 back in this weekend.
Just my general theory.... something makes it past the fuel filter clogging the #8 injector, goes lean under boost and high rpm, causes detonation and melts piston, crankcase pressure goes out the wazzu because of that and dipstick blows out and forces oil through the exhaust to the turbo...the ac busting and blanket catching fire was a separate issue
#344
The fire was probably the oil on the manifold catching. Just as you sometimes see transmitions over heating and they spew fluid out the dipstic. A big ball of flames and it goes out rather quickly.
Maybe this was your thery too but seems like what happened to me.
#347
Of course there was knock right before your fire, you just didn't hear it. I am interested in the results of the injector flow test, and I like 1slow01Z71's theory about too little ring gap. It seems that if rings have enough gap to put up with 20 psi, there is going to be a lot of blow-by, and customers don't like that in a brand new engine. But I have to re-question your knock sensor sensitivity, again using my reoccurring KR as a reference. In my mind, I would have not gone WOT at 20 psi again until I figured out why it was too lean (12.5 AFR) for safety, but in actuality I would do it anyway.
I don't mean to sound insensitive, I do feel your pain, having recently done a rebuild because of a wiped out cam.
I hope you do find the cause so you can put it back together and proceed with confidence.
#348
According the the build sheet, top gap was at 0.024 and 2nd ring at 0.026. I never went WOT with the 20psi spring in there, I could tell it was overboosting with just 60% throttle so I drove it easy until I got the boost reference line hooked back up. The most boost I saw at WOT was 15lbs.
As far as knock pickup I never touched those settings, maybe my sensors need to be replaced anyway?
#349
I am just focusing on knock sensitivity because you melted a piston and say there was no knock. Does that mean no knock retard, or no audible knock?
#350
Both. No retard and no audible knock. Hell I drove it around the block with the hole in the piston and not so much as a code or vibration, just a ton of oil smoke.
I've already made up my mind I'm done modding this truck. Too much time, money, and effort to end up with no dd at the end of the day. Once I get the 5.3 back in I'm putting the sofest spring I can find in the wastegate until I find a stock ypipe to connect to the factory manifolds and the turbo is coming off.
