Lets Try This Again: 410-PT88-80e
Old 12-10-2010, 09:41 PM
  #61
SincalT/A's Avatar
Originally Posted by Atomic
Finished a take home propulsion final on sunday. Got utterly destroyed in a controls 2 final on Tuesday, but so did the rest of the class so im not worried, and had a composite materials test yesterday. I have an econ final on friday which im not worried about, silly business classes
LoL!!! I strugged in BooBieOlogy thanks for being smart so I dont have to...
For real though i've had a few and do appreciate your kool *** build.Keep it up Richard...
Btw...That took a long time to type and make sense.
Old 12-10-2010, 10:06 PM
  #62
GMCtrk's Avatar
what will be the specs on your converter?
Old 12-10-2010, 10:15 PM
  #63
I have a gauge for that
Atomic's Avatar
I sent my 2600 triple disc back to PI and told them to make it work for an 80e and keep the LS1 bolt pattern so I can use a normal flexplate. I also told them to tighten it up some, so it should stall around 2000 im guessing. I got it back yesterday in case I didnt mention that.
Old 12-10-2010, 10:20 PM
  #64
GMCtrk's Avatar
I think you've made a really good choice on the converter and having it tightened up.
Another option would be to just use the stock 80e converter. Only downside is 30lbs more rotating mass than the Vig.
I've got a Yank 3600 in my 80 and I'm looking to change it up for something tighter and add a lot more power.
Old 12-10-2010, 10:25 PM
  #65
Atomic's Avatar
Yea, I like driving with the stock torque converter much better than even the 2600 it was before, I feel a ton slower but its much more pleasant to DD... I dont have a stock 80e converter, so it was an easy decision to have my nice one modified to work.
Old 12-10-2010, 10:28 PM
  #66
GMCtrk's Avatar
gotcha, yeah, my 3600 can be annoying at times. Oh, did I mention I barely get 10mpg. The thing about the 80e is that in 4th the converter always unlocks when you go to 0% TPS. Not a problem or even noticeable with the stock converter, but with a higher stalling one, damn thing will shoot up to 2500-3000.
I'll probably just use the stock converter. I'm really dreading pulling the trans though.
Old 12-10-2010, 10:33 PM
  #67
Atomic's Avatar
Ive pulled the trans so many times im used to it by now, the tough part is lifting it up on the jack while im laying on my back under the truck.
Old 12-10-2010, 10:35 PM
  #68
GMCtrk's Avatar
For just a converter swap I plan on keeping it on the jack and simply pull it back from the engine just enough to get the converter out. Gotta have enough room to put the 80e flexplate on too.
Old 12-10-2010, 10:42 PM
  #69
SincalT/A's Avatar
Ha,I kinda know what you mean.I have done a few tricep extensions with the ol'60e and converter on a jack.Im sure the 80e's gonna be a even more pleasent work out when i stab it.
Old 12-10-2010, 10:46 PM
  #70
Atomic's Avatar
I had PB on bench the other day with a clean 415 lift, I was pretty happy with that. Stupid transmissions can suck it.
Quick Reply: Lets Try This Again: 410-PT88-80e
