Ls6 5.7/T-56 swap 04 Silverado RST
Old 04-24-2012 | 09:29 AM
rcsb jon's Avatar
Best wishes with the electrical issue.
Awesome combo
Old 04-24-2012 | 10:07 AM
89LS1FOXER's Avatar
A 1 volt drop will not be enough to hurt anything, you either have a bad engine ground or something is keeping the engine from turning over..... re-check your main grounds and try turning the engine over by hand..
Old 04-24-2012 | 11:01 AM
JesseRst's Avatar
awesome setup bro, cant wait to start my ls1/t56 swap! good luck with the starting problem 89ls1foxer really knows his stuff his advice should be pretty helpful
Old 04-24-2012 | 03:05 PM
kren7604's Avatar
Could it be too much compression with my cam?? it's at like 11 3/4:1 compression cam is comp 224/230 with comp 918 springs
Old 04-24-2012 | 08:00 PM
kren7604's Avatar
Engine turns over fine by hand, rechecked all grounds to engine... Could it be my truck flywheel I reused, is there a difference between truck and ls1 flywheels?
Old 04-24-2012 | 08:23 PM
89LS1FOXER's Avatar
YES! The truck flywheel is designed for a NV3500 trans and clutch assy, you need a LS1 f-body style clutch and flywheel....
Old 04-25-2012 | 02:33 PM
kren7604's Avatar
Figured it out lastnight, pulled tranny so I could see Wat the starter was doing.. For one the truck flywheel has a deeper bowl to it( about 1/4") deeper.. So my starter couldn't reach the flywheel teeth, I swapped out flywheel lastnight with Ls1 lightweight aluminum one, but it still isn't lining up all the way, it's about 1/8" off so I'm Gona try an shim the starter this weekend
Old 04-25-2012 | 08:51 PM
Ferocity02's Avatar
Is that the forward shift conversion?
Old 04-25-2012 | 10:44 PM
kren7604's Avatar
Yes, made by Keisler
Old 04-25-2012 | 11:30 PM
kren7604's Avatar
Here is what my truck was doing when i try to start it
and here is the difference between flywheels
