LSX 438 Twin Turbo
#841
Hi Mark I have been watching your build and did not want to say much because this was about your awesome Denali . I just updated my dyno computer and software and as soon as I figure out how to pull the file I will more then happy to post the dyno sheet . I am running C16 race fuel at 16 psi and I put down 991 hp spining the slicks on my dyno. I have lot more work to do . We took the Truck to the track to see what other problems we would have. Out of 4 passes we could not stay on the throttle in high gear because the truck was too loose . Then in the pits we found water in the oil . So I have to pull the heads now see what is up with mls gaskets and why they failed. But that just a part of making horsepower and fixing the weak links. I will keep you posted .
Ed
Ed
#846
hehehe. Very sneeky.
Its on the other side instead, and goes down under a few pipes then comes back up to the outlet on the top of the water pump.
Rick
