LSX Tall Deck 900hp motor build
#61
Unless I'm mistaken...
The mechanical advantage due to the added stroke that you get from a stock bore/stroked 408 is greater than that of a stock stroke/bored 408. So you'll get more torque from it.
But the advantage of a stock stroke/bored 408 is the surface area you have with the larger bore piston. Then your dealing with the physics related with hydraulics systems.
I wonder what argument some other people would make when you make your statement. I can assure you that even if the hp is similar, that the powerbands would be vastly different.
#64
How do I change this text
eehhhh...hp is rpm dependent, torque isn't.
Offroadunleashed
07-20-2015 02:25 PM
grantpo
07-15-2015 12:21 PM
