More Changes
#21
They had mini tubbed it and sprayed around the wheel wells with an undercoating, then where my fuel cell was ,we had a box made that it would set in and put it in the bed. I wish the battery and fuel cell were reversed but my fuel pump is farther forward. After everything was welded in, they painted inside of bed with factory color. Hope this is what you wanted.
#24
Well , supposed to be 63 tomorrow and clear. Track opens at noon o'clock and they start runs at 1:00. Just a fun drag day. Will run it as the last run and see how much improvement there is. Should be I hope. Then I'm going to do the whole 150 off the line, then go to a 200 shot,programing the progressive controller.
With the spool,ladder bars, coilovers, more tire and 160 lbs. less that should be worth a few 10ths.
Will post as so as I get home.
