how did i miss this? having a 5.3 with flat tops must be nice!! good looking build man. I want to see what the nitrous numbers are. what spark plugs are you running?
it may be awhile before i get any nitrous numbers on the dyno. i have the tr6's in right now and will prolly use those up to the 150 jets. i do plan on spraying a little more than that though and will then switch to the br7ef's or whatever they are.
this particular shift lite just has a power, ground and tach wire. power and ground are obviously self explanatory, and the green tach wire went to pin10 on the green connector of the pcm(white wire) and then set it to 4cyl on the lite
