My 2007 Silverado Build...again
Old 06-02-2010, 05:15 PM
  #81
11 Second Truck Club
fastrt's Avatar
how did i miss this? having a 5.3 with flat tops must be nice!! good looking build man. I want to see what the nitrous numbers are. what spark plugs are you running?
Old 06-02-2010, 05:25 PM
  #82
11 Second Club
Phantom's Avatar
it may be awhile before i get any nitrous numbers on the dyno. i have the tr6's in right now and will prolly use those up to the 150 jets. i do plan on spraying a little more than that though and will then switch to the br7ef's or whatever they are.
Old 06-02-2010, 06:07 PM
  #83
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
What size converter are you running? 4.56 gears right?
Old 06-02-2010, 06:12 PM
  #84
11 Second Club
Phantom's Avatar
yes 4.56 gears. 10" converter
Old 06-02-2010, 06:14 PM
  #85
1slow01Z71's Avatar
Guess I should ask the correct question since you answered mine techinically correct What stall speed is it set up for?
Old 06-02-2010, 06:40 PM
  #86
11 Second Club
Phantom's Avatar
it's 3500ish, set up pretty tight
Old 06-02-2010, 08:11 PM
  #87
13 Second Truck Club
LS1FREEK's Avatar
Dude how did you hook up that shift light?
Old 06-02-2010, 08:33 PM
  #88
11 Second Club
Phantom's Avatar
this particular shift lite just has a power, ground and tach wire. power and ground are obviously self explanatory, and the green tach wire went to pin10 on the green connector of the pcm(white wire) and then set it to 4cyl on the lite
Old 06-02-2010, 09:36 PM
  #89
LS1FREEK's Avatar
Cool thanks... I think I might get one too... It looks great!
Old 06-05-2010, 12:29 PM
  #90
11 Second Club
Phantom's Avatar
finally got to spray it last night...she moves out pretty good!
Quick Reply: My 2007 Silverado Build...again
