My 2016 Escalade Build
Restricted User
installed the husky liner kit and covers it all. I have few extra sets for the 07 up gm trucks single/extended/crew cabs etc here if anyones interested. Just holler will save you few bucks over summit or jegs.
Is it as easy as using a heat gun and stretching and smoothing the 3m vinyl over the pieces then trimming with a razor blade, it looks much classier with it over the wood grain. Would look to do this in my 2008 as I dislike the wood grain very much so.
Restricted User
i like the huskys a lot cant go wrong
so worked late today but got few things done.
Truck was at 35.5 front rear comes in at 38 1/4 ground to fenderlip
Did the free tavel mod on pass side bracket cut off which gives 3 more inches of travel finish up drivers side tomm. Ill prob go back to grind it smooth to the frame but for now just want to get it dropped
insulators on these things are big. I just wrap heater hose on top and bottom coils on them but the oem ones give the truck a 13/16 lift
Belltech 5305 coil left vs oem spring right. Yes i had the belltech springs coated to match oem. OCD strikes again
Restricted User
Finished cutting the drivers bracket put the belltechs in along with the djm links. Rig rides nice and came down 4.25 inches..... but its not low enough for me Ill post up pics with the rear dropped tomorrow. Im planning to do the swaybars and front drop this weekend. I have a feeling ill be putting in my custom spring in rear and getting rid of the autoride to slam it.
26" tires came in today also.
