My 427 Build (e.g. New and Improved BRT transformed into a C5!)
#73
Cam turns out to be a little different than what Rick Squires remembered when he sold it to me.
it's a 232/236 .596/.581 on a 114lsa. With my crane golds, the lift is right where I want it to be. I'm still debating switching this out, especially since I'm now moving to tubular header front mount (which says I should go single pattern) and since the turbos are probably a little small (which says I should go 6* intake biased on a reverse split).
But, both Rex and Richard really like this cam for the motor... hard to really argue with them...
#74
what a rush!
More of teh yummi
it's a 232/236 .596/.581 on a 114lsa. With my crane golds, the lift is right where I want it to be. I'm still debating switching this out, especially since I'm now moving to tubular header front mount (which says I should go single pattern) and since the turbos are probably a little small (which says I should go 6* intake biased on a reverse split). But, both Rex and Richard really like this cam for the motor... hard to really argue with them...
#75
Lil update:
I have a huge orange thing in my garage!
Ended up with a new cam after all -- the old one got a little sick... Rex speced it for me, and from memory, it's a 238/239 .57x/.57x on a 115lsa
I've got a build sheet and some picks to post up later.
Now that I have it here... It's forecast high in the 10's and winterstorm warnings until next August
#76
I feel I should add that I would have stuck with the old cam. Or ground something the same size again if the cam get hurt. Just my two cents. I would hope that with that new cam the turbos are up front this time.
R
R
#77
You must have missed the other thread https://www.performancetrucks.net/fo...d.php?t=420677
Twin front mounts. The old cam was toast, unfortunately (as were the cam bearings that prompted the 427).
#78
Yeah, I miss Michigan....what, with the single-digit temps sans wind, wet snow that weighs in at 25lbs per shovelful (and ensures your fingers and toes don't thaw 'til June), and getting up at 2AM to shovel so you won't have to get out of your second story window at 6AM to dig out the front door. Yeah, I miss it.
#79
Thats a start then. LOL.
You know, I had a cam smaller than your original cam in Marks 438 twin turbo. Turbos dont need much cam, keep that in mind.
R
