My 427 Build (e.g. New and Improved BRT transformed into a C5!)
Old 12-19-2008, 01:20 PM
  #81
zippy's Avatar
That's a bigger cam than I'd have picked with twins, but it's going to sound very nice. I know the cold issue, we also have about 14" here on the ground.
Old 12-19-2008, 11:42 PM
  #82
2004SSS's Avatar
i thought you had to run a gen4 style front cover on the lsx block , did it have to provison for the gen 3 cam sensor?
Old 12-20-2008, 05:42 PM
  #83
I AM A MOTHERF*CKER
TurboBerserker's Avatar
You do It's on there now.
Old 12-21-2008, 08:44 PM
  #84
2004SSS's Avatar
this should be interesting we are doing something very similar.
care to share specs on the turbos?
Old 12-21-2008, 10:14 PM
  #85
Need More N2O Mod
mwalls54's Avatar
Originally Posted by kbracing96
Gees, I'm gona be married and have kids by the time you get this thing running,
Originally Posted by TurboBerserker
Don't make me come over there!
yeah i have been thru there and dont waste your time I think all thats out there are cows and deer.
Old 12-24-2008, 01:01 AM
  #86
I AM A MOTHERF*CKER
From the "moving to front mount" thread: https://www.performancetrucks.net/fo...5&postcount=37
Old 12-30-2008, 10:36 AM
  #87
what a rush!
moregrip's Avatar
updates?
Old 01-05-2009, 02:43 PM
  #88
I AM A MOTHERF*CKER
First: The madman in charge
now some bling:
Here's the nice little 2 piece cover I wanted to use -- dadgum LS2 sensors!!
Here's how nicely the shipper handled my stuff on the way to Rex:
Doh!
Old 01-05-2009, 02:48 PM
  #89
I AM A MOTHERF*CKER
and here's some build info:
Make: Chevrolet Lsx 427
Displacement: 427 CID LSX SB
Bore: 4.125
Stroke: 4.0
Crankshaft: Callies Compstar W (24 time reluctor)
Rods: 6.125 H Beam w Arp 2000 7/16 Bolts mfg.Compstar
Camshaft: Comp. 238@050 int..575 lift 239@050 Ex. .578 lift Hyd
Lobe Separation 115 cam deg. (Intake is at 112) 3. advance Lifters GM Hyd Roller
Rocker Arms Crane Race Gold 1.75:1 advanced lift.
Pistons: Wiseco 18cc dish
Rings: Ackerly and Childs Ductile 1/16x 1/16x 3mm
Pushrods chromoly 7.4"
Valves: Intake 2.08 exhaust 1.600” stainless
Compression Ratio: 9.6:1
Timing Chain: Roll Master Billet double row w LS2 cam gear,timing cover
Oil Pump GM with modified spring, 2 shims
Main Bearings: Clevite 2199. H..std
Rod Bearings: Clevite 663 H std.
Cam Bearings: Durabond
Piston deck -4
Piston to Wall +.005.”
Cyl Heads.. TEA Stage III LQ9 heads
ARP Head studs, 2000 rod bolts, cam bolts, Main Studs
Head Gaskets GM MLS 7 LTR
Old 01-05-2009, 02:58 PM
  #90
How do I change this text
Wilde Racing's Avatar
is .004 out going to give you enough Quench? I love the front Timming cover....
Quick Reply: My 427 Build (e.g. New and Improved BRT transformed into a C5!)
