My 71' Turbo ChevII
Old 06-07-2013 | 05:54 AM
  #31
BrentLantz's Avatar
Registered User
In the above two pics it looked in quite a great condition..i mean the color and the build was just superb..what were the tweaks you were trying to give it according to the pics you posted later.
Old 06-07-2013 | 06:39 AM
  #32
JDC's Avatar
JDC
I don't think you want to mount the turbo solid to the cooler like that. Your engine is going to move and the cooler isn't going to. Something is going to break!
Old 06-07-2013 | 09:16 AM
  #33
nonnieselman's Avatar
I forgot about that.... maybe just take the one mount off the passenger side and let it pivot from the driver side?
Old 06-07-2013 | 03:02 PM
  #34
Benlugchev's Avatar
11 Second Club
Hows this?
Old 06-07-2013 | 08:03 PM
  #35
JDC's Avatar
JDC
That'll help!
Old 06-07-2013 | 09:34 PM
  #36
Benlugchev's Avatar
11 Second Club
So I flashed my tune in it tonight. But she won't start. Not getting any spark at the plugs. I redid all 3 harness grounds. Still no spark. Checked and I have power to the coils. Still no spark. I'm thinking I painted over the crank sensor terminal plugs when I painted the block. I'll switch the cranks sensor out tomorrow and see what happens. Thing turns over nice almost too fast. Hopefully we have " fire in the hole" tomorrow and hear her rumble.
Old 06-07-2013 | 11:30 PM
  #37
ak2007r6's Avatar
Can't eat to hear it. Hope the new sensor takes care of the issue
Old 06-08-2013 | 10:36 PM
  #38
Benlugchev's Avatar
11 Second Club
So after a very frustrating day of dealing with the electrical system (not my favorite)
installed new crank sensor - still no spark
installed another set of coils both sides (round type) and was able to get her to fire up and run very rough at idle. Not sure if it is tune related or electrically related and getting a misfire.
Laptop was dead and couldn't do any efilive logging or DTC troubleshooting with it today.
I my have some sort of electrical issue though.
Anyone know if this way I wired is correct and why I might be popping this fuse.
The truck is wired the following way.
I have a 10 gauge wire with 15amp fuse coming off the back of the alternator that feeds my distribution block for all my other 12V hot wires. (should this wire come straight from the + batt instead?)
2 gauge wire going from + side of batt to starter
10 gauge wire going from larger post on the starter to back of alternator.
Purple wire comes from the stock C10 harness at firewall going to the smaller post on the starter
Truck seems to turn over very fast?
When the fuses kept popping, it also happend to be the same time I had the charger box on the battery, not sure if this is what was killing the fuse or not?
Old 06-09-2013 | 10:14 AM
  #39
Chevy-Fun's Avatar
my 84
battery+ 2 cables- one to starter 2gauge, one to alternator 4gauge
starter- has main cable from battery 2gauge, an smaller 8-10gauge? to distribution block on same terminal big post of starter
starter small post goes to ignition
i believe thats how mine is. its raining so cant really go out an look.
hope this link explains it better
Chevy Truck Underhood Wiring Diagrams
Old 06-09-2013 | 09:20 PM
  #40
Benlugchev's Avatar
11 Second Club
Originally Posted by Chevy-Fun
my 84
wow thanks an electrical diagram that i can actually read without having to study it for and hour. thanks for sharing man.
Quick Reply: My 71' Turbo ChevII
