Originally Posted by Choda
(Post 5397080)
I'd say stock oil pulp and water pump are fine.
China studs are good Looks like you have a good list. I would only add new motor mounts. I didn't replace them w mine with 100k miles. |
Not much for aftermarket mounts.
Parts are starting to show up. Getting excited but pistons take about 3 weeks to make. So wont be doing anything til they show up. Then the machine shop will probably be another few weeks. This is what circle D recommends for stall converter. What do you guys think. I dont know anything about them but sounds about right since I have to tow camper sometimes.
We could try a tight 258mm converter. This would get us in the mid 2K footbrake RPM which should be great for this sized turbo and still be decent for towing use. For lockup, I would recommend you opt for the triple disk. Thougths? |
Originally Posted by crashmymax
(Post 5397131)
Got my pistons today. Going to send the block off to ft Collins in about 2 weeks. I am pretty sure I will have them assemble the short block. I have to much money in it now to risk doing it myself.
https://cimg0.ibsrv.net/gimg/www.per...c4ae940388.jpg |
Got my drive shaft in today. This should keep up with the new motor. Hopefully it will get rid of some of that clunking as well.
https://cimg7.ibsrv.net/gimg/www.per...e71ef722da.jpg https://cimg6.ibsrv.net/gimg/www.per...5a4335ff15.jpg |
Decided to try and make this ugly truck intake look better for the new engine. First lesson is melted hot intake material will melt a good hole in your flesh when it lands on you. Lol. Figure I will get it fairly smoothed out then put on a few layers of fiberglass to cover up the holes. Hopefully it will stick and be strong enough.
https://cimg3.ibsrv.net/gimg/www.per...af9e6757b9.jpg https://cimg5.ibsrv.net/gimg/www.per...4dd47bbe5f.jpg https://cimg6.ibsrv.net/gimg/www.per...cd251c458b.jpg https://cimg9.ibsrv.net/gimg/www.per...a61e58a0f8.jpg https://cimg0.ibsrv.net/gimg/www.per...666662aca7.jpg https://cimg3.ibsrv.net/gimg/www.per...d94df54563.jpg |
Had some time to start to lay down some glass. If it sticks I think it will end up looking fairly decent.
https://cimg5.ibsrv.net/gimg/www.per...6d89a787f9.jpg https://cimg6.ibsrv.net/gimg/www.per...f4763c671c.jpg https://cimg8.ibsrv.net/gimg/www.per...c2215dfa7f.jpg https://cimg0.ibsrv.net/gimg/www.per...9b1e8b7573.jpg |
This little project is taking up way too much time. I'm definitely no body guy guessing at least 2-3 more hours of filler and sanding before I'm close to a smooth finish.
https://cimg5.ibsrv.net/gimg/www.per...84e8d6c385.jpg |
