My large frame front mount project with two videos
#183
How do I change this text
Well quite-ish is just another fine example of my spelling ability. "Quiet-ish" would be a little less noisy than my old set-up... Which I think I can manage, as long as the pipes don't rattle against the frame, cross members, cab, heat shields, engine and trans...
#184
Well I worked on the pile again tonight. Didn't get to much done though..
Waste gate is welded to the manifold, but I still need cut the pipe that connects the gate to the down pipe. I also got the turbo support pretty much done...
#185
Well after another 3o,clock night... The turbo support and the exhaust are DONE (not including down pipe). I ended up going with about four feet of 5 inch after the down pipe then down to four inch, through a muffler then out the stock location. I have my old three inch cut out right after the down pipe.
The waste gate is pretty much done, I just need to install the divider I'll post pics of that. And install a wide band bung. So the hot side getting close to being wrapped up.
So the truck is back on the ground, and WAY dirty...
#188
ARE YOU F-ING KIDDING ME???? I WILL NEVER EVER EVER build all this crap in my garage with a cheap *** wire welder, a grinder and a chop saw again BTW, YOU do not charge enough for your manifold.
