My large frame front mount project with two videos
#201
How do I change this text
It is, and I love doing the work, just frustrating when under a tight time restraint, noise restraint and lacking of tools< which is a big issue for me. I have WAY more money in tools than I do my truck.
#203
Thanks Dude.
Well I got a bit more done last night...
I got the frame wax striped, the frame painted, and the ABS harness rerouted. I also finished up my oil cooler support. (pics of that later)
At work, I got my split exhaust, single waste gate flange idea going. Each bank will remain divided. The waste gate valve will seal up (somewhat) at the end of each port, once the gate opens both sides merge, and are bypassed. I'm pretty sure it will work, my only worry is, now the gate wont flow enough to keep boost steady... I'll just have to try it and find out..
Still need a little clean up, but you get the idea..
#206
Dusty you're a metal sculpting artist. How did you remove the frame wax? The less ecologically sound the method the better (pressure washer filled with benzene). I would like to clean the bottom side of my frame rails.
John
John
#208
Thanks guys.
I removed about fifteen feet of wide band wire, and started bending metal for the heat shield. Hopefully I'll have the turbo installed and the fender bolted back up this weekend.
#210
Well, it's actually going together, finally....
Down Pipe all wrapped up..
Manifold, and turbo support.
Turbo mounted
And the money shot...
PLENTY OF ROOM!
Turbo mounted
PLENTY OF ROOM!
