My lifted 00 silverado Lq9 swap and turbo build
Old 01-12-2015, 08:08 PM
  #91
GREENSIERRA's Avatar
Originally Posted by black00chev
Its a tough swap when you're 4wd and you have to mess with the t-case and driveshafts.
My truck is 4wd
Swapping the input shaft in the tcase is a half hour job, drive shafts is a matter of taking a measurement and bringing it in
Did the swap by myself with hand tools in a day easy
Old 01-13-2015, 12:01 AM
  #92
98tdi's Avatar
Originally Posted by zaathur151
I will from what I here he specializes in LS engines and is making a good name for him self in my area. I am mine blown with a rough tune with no timing and over fuel with only 6psi how easy it will smoke my 33.5" mud tires off
Who is your tuner?
Old 01-13-2015, 09:51 AM
  #93
zaathur151's Avatar
Originally Posted by GREENSIERRA
My truck is 4wd
If I ever did it I would like to use the T-case off a 2500HD That way it would bolt right up and have a stronger T-case and ditch the AutoTrac
Old 01-13-2015, 09:52 AM
  #94
zaathur151's Avatar
Originally Posted by 98tdi
Who is your tuner?
Justune in independence mo.
Old 01-14-2015, 06:28 AM
  #95
I run a 246 but I picked up a 241 for when I do my SAS
Have you looked into doing that 2500hd swap? Got a buddy with a 07 nnbs 1500 wanting to do that swap and every company he has talked to said its a no go
Old 01-14-2015, 01:25 PM
  #96
zaathur151's Avatar
UPDATE VIDEOS
DYNO today 488HP 452.59 Torque
60-120 PULL
Old 02-21-2015, 08:26 AM
  #97
newmexicosaint's Avatar
Subcribed
Old 05-26-2015, 12:38 AM
  #98
ice17's Avatar
I have a turbo Suburban we can't finish tuning. What are you running for the rear end? I've gone through a 2nd Yukon posi setups now with 4.56 and 400lb springs. Keeps chewing up spider gears. Can't find the ghost that causes this. I have a built 4L60 with a ton of 65/Allison/Vette parts, shift kit and a 2400 stall built Trailblazer converter. Looking to go back to 3.73 and add a girdle to see if it helps. First time I blew it with my old supercharger on the very 1st 1-2 shift with 365whp. This time was a lot more power but same failure.
Your build looks awesome. Keep the updates coming
Old 05-28-2015, 08:30 AM
  #99
zaathur151's Avatar
I still have the factory G80 3.73 rear end with 240k on it works great have had no problems with 500 to wheel. but I don't have a lot of miles yet on the truck with that power I blew 3/4 clutches on my 4L60E about 6,000 miles after the build, waiting on funds for a 4l80e setup.
Old 05-28-2015, 08:42 AM
  #100
zaathur151's Avatar
Small update on lowering it small amount to get my CV axles more horizontal & tie rods and found this set of used wheels 20x10, brand unknown with 305/50/20s with only 1st and 2nd gear she will haul *** tell 50mph lol
Quick Reply: My lifted 00 silverado Lq9 swap and turbo build
