My lifted 00 silverado Lq9 swap and turbo build
Old 12-03-2014, 09:04 AM
  #21
zaathur151's Avatar
Originally Posted by Choda
What intercooler is that? Which turbo also?
I put my 40k behind my front mount and it works great. I mounted it as high up, just about flush w the top of the rad, as I could to keep air flow through it as much as possible.
Its the trick turbo stage 3 kit with 74/75 precision turbo
Old 12-03-2014, 09:13 AM
  #22
zaathur151's Avatar
Here a pic showing about half a quarter of room
There is tons of room between the radiator and condenser anyone think this would cause a problem if i put it there
Old 12-03-2014, 09:17 AM
  #23
zaathur151's Avatar
Little update cut hole in bed to easily remove sending unit I have a old wrecked bed im going to cut for a block off plate
Old 12-03-2014, 10:31 AM
  #24
Choda's Avatar
Originally Posted by zaathur151
Interesting I wonder if something is bent on mine i'm not finding, because my condenser is almost touching the hood latch frame
different body style trucks too. Mine is a 09 which is NNBS
Old 12-03-2014, 11:21 AM
  #25
ShredSled's Avatar
Could possibly mount it down in the bumper vent...
although if you do mount it in that gap between condenser and radiator it may possibly increase the efficiency of your fans. I could be wrong though.
Just wondering why you didn't go with upgraded rod bolts while the pan was off?
Old 12-03-2014, 07:59 PM
  #26
slowmo934's Avatar
I have the same front end on my Suburban and this is how I mounted mine.
Size:  79.6 KBName:  20141029_201134.jpg
Old 12-03-2014, 08:56 PM
  #27
zaathur151's Avatar
To be honest I didn't think of that I had a machine shop just fresh it up with rings and bearings months ago
Old 12-04-2014, 09:53 AM
  #28
zaathur151's Avatar
another little update walbro 255 fuel pump is done pretty easy
Old 12-04-2014, 01:56 PM
  #29
zaathur151's Avatar
Need some opinions on water/meth injection kits I have been looking into AEM Kits 30-3300
because of my higher compression of the lq9 thats at 10:1 along with 10lb of boost on 91-93 pump gas would this be a good idea and what would be the HP typical gains if I add this?
Old 12-04-2014, 10:03 PM
  #30
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
yeah do a meth kit I'm running a 10:5:1 6.0 with 12lbs runs like a champ with 18* timing up top and i plan on going up to 14lbs or 15lbs soon
I'm running a alky control meth kit with a single 10GPH nozzle
Quick Reply: My lifted 00 silverado Lq9 swap and turbo build
