My lifted 00 silverado Lq9 swap and turbo build
Old 12-05-2014, 07:13 PM
  #31
zaathur151's Avatar
Updates!! motor is in and turbo plumbed
Old 12-08-2014, 09:35 PM
  #32
zaathur151's Avatar
Need help guys with the trick turbo kit I have 2 wastegate flanges, I put the wastegate on the turbo manifold but what goes on the other one? Was there a block off plate that was suppose to come with the kit?
Old 12-08-2014, 09:37 PM
  #33
ShredSled's Avatar
Wastegate.
Old 12-08-2014, 09:43 PM
  #34
zaathur151's Avatar
Originally Posted by ShredSled
Wastegate.
Sorry I edited that I was meaning wastegate
Old 12-08-2014, 10:00 PM
  #35
ShredSled's Avatar
Ha OK now I see you added that last pic.
Does your downpipe have a recirculation opening at the top or bottom?
Old 12-09-2014, 03:49 AM
  #36
zaathur151's Avatar
Nothing else on down pipe other than 2 bongs for wideband and O2 sensor
Old 12-09-2014, 04:30 AM
  #37
Choda's Avatar
Block one off. If you don't have a dump tube for how the WG is set up now it's gonna get exhaust **** and add heat all over your engine bay
Old 12-09-2014, 10:29 AM
  #38
ShredSled's Avatar
You been rippin those bongs?
Well I'm not too familiar with the Trick setup. It appears you have the option of wg location.
The lower one on the crossover was more common awhile ago and seems easier to vent to atmosphere, but can cause boost creep since it really is only doing the drivers side bank. The one on the log would be more accurate in its control... But may be harder to route if it didn't come with a recirc to dp. You can just make your own exhaust for it though.
Old 12-09-2014, 06:45 PM
  #39
zaathur151's Avatar
Must have been high when I wrote that lol. I have a block off plate on order for the extra wastegate flange and I found a few exhaust dumps for a wastegate on ebay I may go with.
Old 12-11-2014, 09:06 PM
  #40
zaathur151's Avatar
Had UPS show up today trans cooler, aem boost controller, a few fittings for fuel pressure gauge and some exhaust tape. Should have my fuel pressure gauge and wide band in the mail tomorrow
Quick Reply: My lifted 00 silverado Lq9 swap and turbo build
