My lifted 00 silverado Lq9 swap and turbo build
Old 12-24-2014, 01:41 PM
  #61
zaathur151's Avatar
Ok took waste gate off everything was working perfect I dropped the spring down to a 4psi spring and still spikes I hit 16psi at WOT here is my setup
Old 12-24-2014, 04:34 PM
  #62
GMCtrk's Avatar
Probably needs a bigger wastegate.
Old 12-24-2014, 08:32 PM
  #63
zaathur151's Avatar
It's a 39mm waste gate that came with the kit
Old 12-25-2014, 09:36 AM
  #64
zaathur151's Avatar
Here is a idle clip
Old 12-26-2014, 09:19 AM
  #65
pewter6.0's Avatar
I don't think those waste gates like being hooked to a vacuum source. I have mine referenced off of the compressor housing, which is only boost. The wastegate needs the boost pressure reference to help it open.
On the other hand, when I put my 4" down pipe and exhaust on, my 38mm wastegate had extreme boost creep. I now have a 60mm wastegate and can maintain 4lbs rock steady.
Old 12-26-2014, 10:08 AM
  #66
zaathur151's Avatar
I will try going off the turbo, good point
Old 12-26-2014, 12:57 PM
  #67
zaathur151's Avatar
What brand and place are you guys getting a vented catch can?
Old 12-26-2014, 02:22 PM
  #68
pewter6.0's Avatar
You will still have pcv fumes inside with a vented catch can.
Old 12-26-2014, 04:31 PM
  #69
zaathur151's Avatar
I'm just venting the valve covers right now and tired of the oil smell but I have never read so much back and forth between vented catch can or vacuum can and setup, it's making it hard to decide what's best for my setup
Old 12-26-2014, 06:05 PM
  #70
pewter6.0's Avatar
The oil smell was my main dilemma when the ac was on. The vented catch can will still smell inside, it will just eliminate the mess all over your engine. A vacuum catch can takes more to setup properly, but is the best setup imo.
Quick Reply: My lifted 00 silverado Lq9 swap and turbo build
