My "mild" street build
So i'm still a noob to this whole truck world. Theres many things I don't know yet, but there are also many things I have learned. Being a "horsepower" addict as many others on here, its come to the point where I'm about to do a 6.0 swap. Heres a quick list of the things that are going in a 2001 extended cab.
Lq4 (zero out, new bearings, new piston rings)
sdpc stage 2 243 heads
230/236 .613/.620 113+2 LSA
2.02"/1.575" Stainless Steel Valves
Patriot Extreme .660" Lift Dual Valve Spring Kit Complete with Dual
Springs, Titanium Retainers, Seats, & Seals
7.425'' Hardened Chromoly Pushrods
Ls6 ported oil pump
Ls6 valley cover
ls7 lifters
ls2 lifter trays
Elderbrock 2 piece timing cover
N motion adjustable timing chain
Arp head bolts
Arp rod bolts
Fast 102mm lsxrt intake
Nick williams 102mm TB
Nitrous Outlet 102mm plate
Nos "wet" kit
40 lb injectors
Asp underdrive pulleys
If yall have any suggestions or ideas let me know. thanks
Ls6 ported oil pump
Ls6 valley cover
ls7 lifters
ls2 lifter trays
Arp head bolts
Arp rod bolts
Nos "wet" kit
40 lb injectors
I run the same duration cam, but with a .581 lift, on a 114 lsa. My friend sold it to me. It was a nitrous cam he spec'd. I think you're going to like it. Is the lsxrt the truck or car style?
Real interested to see what kind of power you put down with those heads. A head swap is going to be my next engine mod.
wheels are 20'' boss 330s on 275/45/20. I like the wheels but trust me as far as small wheels go for the track i will be ordering bogarts and tubbing the bed. i actually just ordered the tubs so i can tuck me some meat. these 20's are just my street wheels, but trust me it'll still get up and go even though their heavy.
