My ongoing project
#121
1 Post
that would be awsome if you dont mind.
the hsw microedge manual says to get the tps sensor wire is dark blue at pcm pin 24 red conector.
i would assume that i could also get the same wire at the tps sensor on the throttle body?
and the rpm wire is white at pcm pin 10. but cant i tap a wire on a coil or injector?
#122
1 Post
Got my cam and HD2 shift kit in yesterday.
its a comp 220/220 .581/.581 112 LSA
same as tsp220
got to order valvesprings and pushrods now.
and a set of tires.....thinking either mickey thompson et street radials or hoosie quick time slicks.
i want something i can bolt on for the weekend and put a fair amount of miles on them. there going to go on my stock 16's.
any opinions?
same as tsp220
any opinions?
#124
#127
1 Post
springs and pushrods should be here anyday now......oh yea also got some mickey thompson et steret radials 255/50r16s
im debating if i should go ahead and pull the heads to have them milled or order the scoggin dickey valve spring tool.....price difference isnt much.
also ordering the cam swap gasket kit and balancer bolt tonight.
#128
1 Post
well went ahead and ordered a cam swap gasket kit and scoggin dickey valve spring tool.
after cam swap and tires are on.....im going to test out the juice!!!
