My rebuild thread
Old 06-02-2008 | 05:44 PM
  #41
2005 Silverado's Avatar
SPAM HUNTER
I have to defend them, most of the post i read from Chris or Bill actually have meaning, some times they dick around, but Bill and Chris are good mods!
But be warned Chris can be kinda if you know what i mean
Dustin
Old 06-02-2008 | 07:56 PM
  #42
350SS's Avatar
Originally Posted by thunder550
No, I have the older style 4L80E that doesn't have the long fitting like that. I think that's exclusive to the newer style 4L80E.
Good deal, didn't know that about the older 4l80's and I know if you don't run that extended fitting on the newer ones, you'll have problems. Looking forward to the seeing the upgraded fuel setup
Old 06-02-2008 | 08:08 PM
  #43
trever1t's Avatar
2nd fastest 5.3 ECSB
....so what about the 4 barrel tb?
Old 06-02-2008 | 08:16 PM
  #44
Stoichiometric's Avatar
Once you fill the master cylinder with fluid start pumping the brake pedal once and while when you are working on the truck. I don't know if I messed up by not bench bleeding the master cylinder, but mine took a long time to get the air out up top. Once that air was gone bleeding the lines was quick.
Old 06-02-2008 | 08:55 PM
  #45
vanillagorilla's Avatar
Looking good Chris! This might be just what your truck needs to push it that extra little bit into the 10's.
Old 06-03-2008 | 12:28 AM
  #46
thunder550's Avatar
High on diesel fumes
I did bench bleed the master, so hopefully I'll be good to go.
Thanks Todd How's your truck doing? Did you ever get it back from paint jail?
Got the shocks and bumpstops put in tonight.
My trimmed fronts vs new fronts
Trimmed rears vs new rears (don't mind the ugly guy in the background)
Rear stuff installed
Front stuff installed (this is not final ride height since I'm missing about 500 lbs under the hood)
Old 06-03-2008 | 12:34 AM
  #47
SPAM HUNTER
Looks good chris, Oh and did you get to use the airbags, or was the truck broke? How do you like them?
Dustin
Old 06-03-2008 | 12:40 AM
  #48
chevyguy7802's Avatar
Looks good bro!
Old 06-03-2008 | 11:06 AM
  #49
thunder550's Avatar
Originally Posted by 2005 Silverado
Looks good chris, and how did you get him off the couch? Oh and did you get to use the airbags, or was the truck broke? How do you like them?
Dustin
I got to use them for a few days....seems like they will work well. The smoothed out the ride a lot in the rear, but I never got a chance to load the back end up and see how they do. I'm looking forward to hooking up the boat and towing with the bags.
BTW, I'm deleting the BS posts
Old 06-03-2008 | 11:22 AM
  #50
BigCountryx's Avatar
Obviously I can't tell how soft those bump stops are, but you are riding pretty close to them. If they are too firm, I'm running belltech 4920 foam bump stops front and rear and love them. Soft and squishy with no hard bottoming out, just a progressive stop. Just an idea. Also you could get rid of that bump stop perch for some more travel. Looking good, outta be up in no time!
Quick Reply: My rebuild thread
