My SquareBody Project.........DIY budget, driveway build
#24
after returning the McGaughys brake kit I sourced my own brake parts. Most of them come from Raybestos professional line (calipers, rotors, flex lines). Used the Raybestos Advanced Technology Ceramic brake pads. Many years ago I worked at a Texaco gas station and the owner who I respect quite a bit, swore by Raybestos. Going to add power brakes vs the stock manual brakes; Tuff Stuff master cylinder/power brake boost combo and Right Stuff Detailing front brake hardline kit and proportioning valve. Using Timken bearings and seals.
#27
Looking good. Did you remove the crossmember with the engine still in the truck. An let me know how you like the frame coater. Sand blasting takes a bit of work. I did some control arm at work but never did the other side. In the end I just order some cpp uppers n lowers.
"will do" on the frame coating!
