My truck
#41
looks good, you need to go bigger, 6.0. people always talk smack about bad gas mileage, I stuck in an lq9 had it tuned for 91 and get 21mpg on the highway if I'm easy on it, on street tires but still. there is no comparison.
#49
So some of you guys have been asking alot about the fans, well here ya go....
PARTS:
I bought 2 of these fans.....
14 Universal Pro Cool Electric Cooling Fan with Reversible Curved Blade | eBay
I was able to get a piece of galvanized metal for $20 im sure the prices will vary but shouldn't be too bad its about 1/16" thick.
Need wiring, fuses, silicone, and self tappers.
DIRECTIONS:
1. I Got the galvanized and had it cut to 29 3/4" X 21"
2. I had to use a grinder but i traced out the fans "od" and cut about a 1/4" inside of the lines to form the hole.
3.Once i got the holes cut out i sanded the galvanized then sprayed about 4-5 coats of high temp clear coat on it.
4.I then layed out the fans and use self tappers to mount them to the metal, once i floated them into place i applied high temp silicone around the whole fan "x2" to help secure and seal the fans.
5. Once the silicone dried I slipped the fans behind the radiator and used 5 self tappers to secure it to the radiator support.
6. We then hooked up the wiring, i had some issues finding the fuse to tap into so we just ran 2 toggle switches inside the cab. " made sure you add 2 fuses in the harness"
Pictures:
Fans when they came in
http://i786.photobucket.com/albums/y...-38-44_989.jpg
Fans layed out ready to trace
http://i786.photobucket.com/albums/y...7-23_189-1.jpg
A look at what i came up with
http://i786.photobucket.com/albums/y...7-17-51_57.jpg
Heres a picture of the fans mounted and everything cleaned up pre-silicone
http://i786.photobucket.com/albums/y...-51-57_109.jpg
Mounted in the truck
http://i786.photobucket.com/albums/y...-48-09_598.jpg
http://i786.photobucket.com/albums/y...-32-14_732.jpg
We tucked all the wires, and it looks alot cleaner with the intake and such on. if i need more pics i can take em. we did the swap along with the stall so i was in a bit of a rush. hit me up if u all have nay questions.
PARTS:
DIRECTIONS:
Pictures:
