My truck
#81
thanks man, ya it deff drives alittle different. almost wish i had gears or a bigger stall but everything spec'd out for the turbo. im gunna try and start rounding up the small stuff in the next few weeks
#83
well heres my next mod...
Plans are,
CXRacing GT45 GT45R Ball Bearing Turbo Charger 80mm wheel T4 1.15AR, on 10-12 psi
80lb injectors
Warlbro 400- ACQUIRED......
DevilsOwn stage 2 meth kit
Brian Tooley .660" LIFT PLATINUM SPRING KIT WITH TOOL STEEL RETAINERS
COMP CAMS LS ROCKER ARM TRUNNION KIT
Tru-trac rear end.
PlX boost & fuel pressure gauges
New D-Max exhaust. - ACQUIRED.....
HP Tuners Pro
Plans are,
80lb injectors
Tru-trac rear end.
HP Tuners Pro
#89
ya now haha, $1400 was kill'n me. just gotta keep jamie from having me buy more appliances around the dam house haha i hope to get the fuel part in the next 2-3 weeks. then prob the gauges. then the springs and rocker upgrade. do all that then the turbo. get it rolling at 5psi or so and then save up got the meth kit and let er rip
#90
also i was wondering what fuel pump should i run? ive seen a few people sunning the 255 and the 340 stealth. would those work since im not going crazy or should i just bump it up to a 400 or sumthin.
