My turbo build..
#57
I also have the 3.73 gears put in, right now im working on my fuel system so I can run 85 on it. I have a single 255 pump in place of the stock one and have 1-2 inch fuel rails with 80# injectors, what I did was add a second pump beside the other in the bowl and just ran a second fuel line up to the rail. Should flow plenty for the pumps.
Just have a few other small things to do and it should be ready to see the track. In a month or two I hope if nothing comes up.
#58
Well shes back together and going again! Im liking the new combo quite bit better, drives around like stock yet pulls hard a lugs the engine better, getting 1000 rpm shift drop now instead of 600 with the same power and shift points. Heres a few vid of me racing some buddys of mine...
This is a camaro with a lq4, tea stage 2 heads, ms4 cam, ported ls intake 90mm tb, 1 7/8 headers, fob, t56, 9in 3.90 gears, me throw the 3in muffler on 16 psi...
This is my buddys new truck he got from a member on here, 03 silverado, 5.3 ls6 heads, 216-216 cam, kb racing turbo kit, 76mm mp turbo, 80e 3k stall, 3.73s, running wm on 10psi, mine was down at 12 psi, we both were on 20s and had a passenger..
lxcoupe
09-06-2017 08:24 AM
jtphelps289
09-11-2015 06:37 PM
06murder
09-04-2015 03:54 PM
