Need swap help(flex plate issues)
Old 07-31-2011, 10:06 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
That little bit of rust, along with being slightly mis-aligned, could have bound it up for a bit. Then "pow", it lined up & snapped into place for you.
Old 07-31-2011, 10:14 PM
SlickSierra's Avatar
ill have to pull it back out after work tomorrow and see how it goes. its not bolted up with the spacer in there
Old 07-31-2011, 10:55 PM
black04's Avatar
1/16" - 3/16" between the flexplate and converter mounts is acceptable. Anything over 3/16" needs to be shimmed.
Old 08-01-2011, 05:50 PM
just measured each crank, they both extend 5/16" past the rear of the block and both snouts measure just under 5/8". so good to go there, i guess the converter wasnt totally aligned with the snout, bout to go back in again and double check the distance from the converter to the flex plate.
Old 08-01-2011, 06:14 PM
06murder's Avatar
only need the spacer for 80e's...which if ur going to put go fast goodies i would go ahead n put one in there
Old 08-01-2011, 09:56 PM
Thanks for the help guys, wound up being nothing. called the transmission shop and they said my gap was fine. everything measured out good so i guess i was worried for no reason.
XL7
05-05-2022 01:48 PM
LCHEE
10-24-2020 04:10 PM
lycominghunter
07-29-2015 04:24 PM
Ketis
07-23-2015 12:37 PM
mrgrim
07-08-2015 08:12 AM
Quick Reply: Need swap help(flex plate issues)
