Never introduced my truck, so here goes
Ill start with a sneak peak:
IMG 0159 - YouTube
0-60 in less than 4 seconds? you bet
427 Aluminum Long Block Includes the following:
* GM LS7 aluminum block
* LS3 Cylinder Heads re-built with High Lift Valve Springs and Ti Retainers (10.7:1 compression ratio)
* 1.85 Ratio Rocker Arm Package, Roller Trunion, Roller Tip, USA 2024 Aluminum Aircraft Extrusion
SLP Custom Spec Camshaft (Camshaft Specs: Valve
* 4.000 SLP/Manley 4340 forged steel crankshaft, Internally balanced to rotating assembly
* 4.125" SLP/Manley 2618 forged alloy pistons (includes new rings including Napier style second rings and full-float pins)
* 6.125" SLP/Manley 4340 forged steel H-beam rods
* Factory-installed cam bearings; Clevite rod and main bearings
* SLP 3 Bolt Core Nitrated Double-Row Timing Chain
* SLP Heavy-Duty, Blueprinted Oil Pump
* GM Lifters and Lifter Guides
* Manley 4130 Chrome Moly (.080" wall) 5/16” OD Hardened Pushrods
* ARP Cylinder head studs
* MLS GM LS7 Head Gaskets
* 58 Tooth reluctor wheel
* Custom blower cam. Lift: .611" Intake /.607" Exhaust Camshaft Duration (@.050 in): 211 degree Intake / 230 degree Exhaust.
Supercharger and Fueling:
* Eaton TVS 2300 Supercharger Lobes
* 3.40” Pulley on the drive side (6 rib), 3.49” Pulley on the shaft (10 Rib), 3.00” Pulley on the blower (10 Rib)
* Custom intercooler base port matched to cylinder heads
* 65 lbs/hr Fuel Injectors
* Fuel Pump Amplifier engaged at 3 psi Boost
Exhaust:
· 4-into-1 Long-Tube Header System, equal-length 1-3/4" main primaries, 3" high flow collectors, mandrel bent 304 stainless steel
· 2.5” O.D. Axle Back 304 SS Exhaust System, Mandrel Bent, High Polished 304SS Straight through muffler
Misc:
· Custom Cold-Air Induction
· Motive Gear 4:11 Gear Ratio Installed by
· Stock Throttle Body
· Transmission Upgrades (Heavy-Duty Clutch Packs)
· Front Brembo Brake Package (Size is 380mmX34mm – 2 Piece – 6 Piston – Fronts)
· 20” x 8-1/2” Chrome GM Wheels w/Pirelli Scorpion Tires
· Chrome Front Upper and Lower Grilles
· Silverado SS Style Hood, Front Bumper Cover and Ground Effects
· Rear roll pan
· Custom Brackets for Ground Effects and Frt. Bumper Cover
Changes on the way:
- big *** custom cam specced by Ed Curtis
- Circle D fully built 6l80
- Circle D 3000 stall triple disk converter
- Richmond 3.73
- Eaton posi
- 10 bolt Girdle + ARP bolts
- Custom true dual exhaust
- ported/polished LS3 90mm throttle body
- Belltech street shocks
- Remove rear lifting blocks
- Custom driveshaft from driveshaft specialist
- ID800 injectors
- 3bar ZR1 MAP sensor
- 160deg thermostat
- Custom 3.5 inch thick Ron Davis radiator + big built-in engine oil cooler and transmission oil cooler + dual high speed SPAL fans
And cant remember what else yes im spending alot of money, will get some pics today
IMG 0159 - YouTube
Exhaust:
Misc:
· Rear roll pan
Changes on the way:
- Richmond 3.73
- Eaton posi
- ID800 injectors
- 160deg thermostat
This is all on the stock pump + BAP though, im looking for a solution to run a bigger pump without messing things up since I have the FPCM. after that I would pulley down for more boost.
im also going to 3.73's instead off the 4.10's which are too short, and the truck doesnt even hit full load in 1st gear. 3.73, full load, few hp mods, and a 3000 stall should make this thing take off nicely!
