Never introduced my truck, so here goes
#64
My 1.85 rocker ratio might make my cam lobes look a little tiny but its no big cam either, specced it based on aloott of variables and cant wait to install it.
Posting pics of the custom ron davis radiator in a while!
#65
the custom Ron Davis radiator with a big a** built in engine oil cooler and transmission oil cooler. This radiator is MORE than 3 times thicker than the stock unit, and has two high speed SPAL fans as well
Check out the workmanship on this unit!!
#67
ok im officially broke LOL.
transmission, Circle D triple plate converter on the way and flexplate along with the richmon 3.73 gears and Eaton posi, girdle and rebuild kits for front and rear differentials.
injectors, camshaft, thermostat, radiator, throttlebody and a few other things in hand.
Need to order the exhaust, a custom big *** intercooler heat exchanger for the blower + a Meziere 20GPM intercooler pump to replace the crappy stock pump for a little higher boost.
Still waiting to hear back from Lonnies performance regarding a dual pump set-up, and wanting to speak to Magnacharger regarding replacing the stock crank pulley for SLIGHTLY more boost.
