Never introduced my truck, so here goes
#71
Ok so I have the Circle D 6l80 on hand
the Circle D 2800 stall triple plate
Richmons 3.73 for front and rear diffs
Eaton posi
SICK Moser Girdle for the 10bolt
5 x .125 aluminum driveshaft, balanced to 15,000++ RPMs
ID850 injectors
custom Ron Davis rad
Custom blower cam by Flowtech Induction + springs, retainers etc...
Circle D Billet flexplate
3.1 vs current 3.2" pulley + a bunch of belts from superchargerconnection
90mm ported throttle body
Will be getting:
Icon front coil over kit with built in shock reservoir + rear shocks
a bunch of gauges
Flyaudio nav touch screen made specifically for Chevy trucks
+ bunch of misc items.
Took the truck to the exhaust shop today for a custom true dual + X-pipe, with two 22.5 inch circular mufflers, dumped. Also have provisions for a resonator tube just in case it resonates at a certain RPM. The current exhaust consists of a CRAPPY 1 3/4 + CATTED 2.5" to 3" y-pipe, which BOTTLES down to 2.75 at the I-pipe and I have pictures to prove!! Will post later
so going from a 2.75" exhaust on an 8psi 427 onto a true dual, I expect to see big gains, also since the cats are going. Power should come from the ability to run more timing due to less boost.
Will post up some pics tonight and tomorrow when I pick the truck after the exhaust is completed.
#72
Right, I also installed a 2" drop spindle, and took off the rear block. With the new tires the front is now ribbing the inner fender well on full steering wheel lock. The reason I changed the tires is because someone STUPID in the build process (not sure who to blame) installed 2003 stock Pirelli tires on my truck, and I found out after I was left on the side of the road with a flat tire!! Had to swap out the four tires and I now have 285/50/20 tires no wonder they're rubbing, but gave me some more speed in gear which I seem to like.
#73
got the exhaust installed, and put in the 90mm ported throttle body vs the truck throttle. Based on injector duty cycle at the same AFR, it went up from 75-76 to 80% which is about a 35 to 40 hp gain, and guess what I could feel the SOTP feeling as well!
Im posting some pics of the exhaust before and after, the previous exhaust sounded REALLY nice at cruise and WOT, with zero drone, but it had no place on a 427 motor. The new exhaust makes my truck sound like my Corvettes (which I like), its a true dual with an x-pipe into dual mufflers, dumped. The only downside is the INSANE amount of drone I now have in-cab lol, will work it out with resonator tubes.
87mm truck throttle:
http://www.flickr.com/photos/alyousuf/6976988323/http://www.flickr.com/photos/alyousuf/6976988323/ by http://www.flickr.com/people/alyousuf/, on Flickr
vs ported LS3 90mm throttle body:
http://www.flickr.com/photos/alyousuf/6830865846/http://www.flickr.com/photos/alyousuf/6830865846/ by http://www.flickr.com/people/alyousuf/, on Flickr
Truck at the exhaust shop:
http://www.flickr.com/photos/alyousuf/6977008373/http://www.flickr.com/photos/alyousuf/6977008373/ by http://www.flickr.com/people/alyousuf/, on Flickr
SLP cat-back Y-pipe:
http://www.flickr.com/photos/alyousuf/6830869988/http://www.flickr.com/photos/alyousuf/6830869988/ by http://www.flickr.com/people/alyousuf/, on Flickr
Notice how the y-pipe necks down to 2.75 inches at the i-pipe.
http://www.flickr.com/photos/alyousuf/6976999365/http://www.flickr.com/photos/alyousuf/6976999365/ by http://www.flickr.com/people/alyousuf/, on Flickr
SLP high-flow cats, turned out to be ceramic high-flow cats
http://www.flickr.com/photos/alyousuf/6830873476/http://www.flickr.com/photos/alyousuf/6830873476/ by http://www.flickr.com/people/alyousuf/, on Flickr
New exhaust, 3" true dual, notice the pipes are argon purged.
http://www.flickr.com/photos/alyousuf/6977017695/http://www.flickr.com/photos/alyousuf/6977017695/ by http://www.flickr.com/people/alyousuf/, on Flickr
The new x-pipe
http://www.flickr.com/photos/alyousuf/6830864644/http://www.flickr.com/photos/alyousuf/6830864644/ by http://www.flickr.com/people/alyousuf/, on Flickr
Mufflers and dump:
http://www.flickr.com/photos/alyousuf/6830862610/http://www.flickr.com/photos/alyousuf/6830862610/ by http://www.flickr.com/people/alyousuf/, on Flickr
http://www.flickr.com/photos/alyousuf/6830899104/http://www.flickr.com/photos/alyousuf/6830899104/ by http://www.flickr.com/people/alyousuf/, on Flickr
http://www.flickr.com/photos/alyousuf/6976994107/http://www.flickr.com/photos/alyousuf/6976994107/ by http://www.flickr.com/people/alyousuf/, on Flickr
http://www.flickr.com/photos/alyousuf/6830877158/http://www.flickr.com/photos/alyousuf/6830877158/ by http://www.flickr.com/people/alyousuf/, on Flickr
While doing the throttle body swap, yes I got people that do everything for me
http://www.flickr.com/photos/alyousuf/6830906816/http://www.flickr.com/photos/alyousuf/6830906816/ by http://www.flickr.com/people/alyousuf/, on Flickr
The new x-pipe
Mufflers and dump:
#74
gotta admit. the SLP was CRAP! the only good thing about it was that it had absolutely no drone what so ever, i liked the HP gain really felt it there, now what should we do about the drone
#78
Here is the Eaton Posi and 3.73 Richmond gears being assembled
http://www.flickr.com/photos/alyousuf/7001055103/http://www.flickr.com/photos/alyousuf/7001055103/ by http://www.flickr.com/people/alyousuf/, on Flickr
Brembo GT Brakes
http://www.flickr.com/photos/alyousuf/6854943100/http://www.flickr.com/photos/alyousuf/6854943100/ by http://www.flickr.com/people/alyousuf/, on Flickr
Mike Frumusa from New Era Performance here to tune a bunch of high hp trucks and cars.
http://www.flickr.com/photos/alyousuf/6854940314/http://www.flickr.com/photos/alyousuf/6854940314/ by http://www.flickr.com/people/alyousuf/, on Flickr
Rear shot of the truck
http://www.flickr.com/photos/alyousuf/6854934920/http://www.flickr.com/photos/alyousuf/6854934920/ by http://www.flickr.com/people/alyousuf/, on Flickr
I personally like this picture
http://www.flickr.com/photos/alyousuf/7001050351/http://www.flickr.com/photos/alyousuf/7001050351/ by http://www.flickr.com/people/alyousuf/, on Flickr
Brembo GT Brakes
#80
thats an opening for the wideband, which is NOT permanently installed. I told them to install it AFTER the x-pipe but I didnt want to complain after I saw it lol. Here it had a rear o2 installed - which is disabled anyways.
Suburban2500
07-19-2015 04:50 PM
Nimoryan
07-05-2015 03:50 PM
