New engine, trans, gears, exhaust, paint, rims etc...
Well I finally decided what I was going to do with the 00 Silverado. New 02 6.0 LQ4 with a Texas Speed Comp Cam(.581-.591 lift, .224-.230 at .050 and 114lc),Patriot dual valve springs, Smith Brothers pushrods with restricted end, Vortech V2 supercharger with a 2.87 pulley, pinned crankshaft,Tune by BlackBear Performance(Thanks Justin!) AEM Bruteforce Ceramic Coated full length headers, custom water to air intercooler, 90mm throttle body, 75lb injectors, Magnavolt booster, Raceland electric cutouts, 2.5" X pipe, no cats, 50 series Big block dual in dual out muffler, built 4l65e, z pack clutch pack, beastie sunshell, upgraded valve body, corvette servo, 2100 stall, changed front and rear differential from 3.73 to 4.10, new axles, new drilled rotors, pads, and stainless steel brake lines, new Pro Comp shocks, truck already has a Rancho 4" lift. Truck is pewter in color and will be Blistering Blue from Planet colors Barrett Jackson collection, new fiberglass SS front bumper cover and a SS roll pan. Painted door handles and factory fender flares, all the side molding removed, 2.5" cowl hood, shaved tailgate handle moved to the inside, spray in bedliner, exhaust will exit through the roll pan, New XD Hoss 795 rims, 20x10 with 325/50/20 Mickey Thompson Baja ATZ,towing mirrors that slide out. The inside gets a triple pod with fuel pressure, boost/vacuum, and a Innovate LC1 wideband, new Escalade cluster, new IGGEE seat covers(black with blue in center and black bowties in each seat), flip out monitor in dash and monitors in each head rest, infinity speakers throughout, MTX thunderform box with 2 10" subs, and US Amp to run the speakers andMTX amp to run subs. In the process of getting this put together and should be done in the next couple of weeks. As of yesterday, engine trans and transfer case is done, body was torn down and in primer. I will get some pics up asap as soon as I learn how to upload from my phone and camera.
The body shop sent a couple of pics yesterday. The truck is back in my home town over 400 miles away where it is being painted. I keep uploading pics when I get them. It's driving me nuts that I cannot be there this week.
I was going to buy a new truck but decided to do this. Now I know what I have and it is what I want. Way cheaper also and no payment!!
I hope it runs as hard as yours does. I only got to drive it from the shop where the engine, trans, and transfercase where switched out to the bodyshop. And that was only about three blocks. I had open headers and I left the supercharger off and did not hook up the new injectors and ecm, ran pretty good except it did not want to idle at all. Can't wait to hook everything up after it is painted and get the exhaust done- man that thing was loud!
More pics today. I called and talked to them and it should be completed by next week. They are using the Planet Color system and it uses colored primer. So what you are seeing in the pictures is the box, hood, tailgate, and doors all in primer. Can't wait till this thing is done.
Making some progress! Take a look at Facebook under Heritage Classics. My friends own the bodyshop and they have pics of the progress of my truck under Kyle's truck. Take a look! These guys do great work. Here's a link:http://www.facebook.com/pages/Bismar...d=223423550393
