Next stage of the build
Old 11-20-2007, 10:54 PM
  #131
FormerVendor
leftcoast32's Avatar
I received the Lingenfelter 100mm MAF today. I just finished the install and re-pinned the new connector needed for it so I didn't have to cut or splice any wires. The installation went great and looks factory. I then had to get all the Short Term and Long Term Fuel Trims dialed in. They are within + or - 1 at idle, I will take it out to stretch it's legs tomorrow and see how it does. Not a bad upgrade at all if you can dial the trims in yourself.
Old 11-29-2007, 10:51 PM
  #132
FormerVendor
I have been tuning the Ligenfelter 100mm MAF and everything has been great. I am no longer seeing a drop in boost from 15 down to 14 at more then 6200 RPM's. The throttle response is instant and it feels much stronger. I need the new tables for the MAF so it doesn't max out in first gear at 512 g/sec as soon as it goes WOT around 4500 rpm's easing into the throttle. I have to slowly ease into the throttle to maintain any traction at all with the BFG KDW's.
Old 01-06-2008, 02:08 PM
  #133
FormerVendor
Testing a couple of new pulley's and polishing some that I already had.
Old 01-07-2008, 12:23 AM
  #134
wastedrubber's Avatar
That engine bay is a work of art! keep up the good work
Old 01-07-2008, 02:20 PM
  #135
FormerVendor
Thanks!!
Old 01-07-2008, 08:37 PM
  #136
what a rush!
moregrip's Avatar
looking good mang, bling bling! I like the dual breathers too!
Old 01-07-2008, 08:54 PM
  #137
FormerVendor
I am just testing the dual breathers right now. I like them so far. Thanks for the Valve Cover!!!
Old 01-07-2008, 09:21 PM
  #138
8ALTNG's Avatar
That is awesome. Very clean and neat.
Old 01-07-2008, 09:27 PM
  #139
FormerVendor
Thanks for the comp. I am having another set of the coil covers made for the change in fuel rails. The Coil Covers really make it look better.
Here is a picture of the 112 with Coil Covers, I had to make some minor changes for the 122HH.
Old 02-01-2008, 01:31 AM
  #140
rpav's Avatar
who makes those breathers? did you end up leaving both on?
Quick Reply: Next stage of the build
