Next stage of the build
FormerVendor
Originally Posted by Tootall
where are the rockers hitting the heads? . . . on the push rod side?
The only down side is that if we have to use 1.8 ratio for clearance I will need to have another cam ground as I have the cam here already and it was ground for the 1.7 ratio.
FormerVendor
Plans changed a little on the rockers. They will need to redesign the push rod cups in order to use the rockers on the L92 heads.
I have a set of the stock rockers ordered from Scoggin and Dickey along with the rocker supports and bolts. I am sending the stock rockers to Harland Sharp for the HS Modification. They change out the fulcrum so the needle bearing don't fall apart. I will post up pictures as soon as I get them back.
FormerVendor
Originally Posted by rpav
i am going to send mine in as well. just waiting for the new set to come in. do you know what they charge for this?
I have not been billed yet because of the change in plans. I have seen it on LS1Tech that they charge $250.00 to do it for you.
Originally Posted by 2005SSR6Speed
Did you get a set of his L92's also?
![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
FormerVendor
I received the modified L92 Rockers back from Harland Sharp today. They remove the needle bearing and replace the pivot with a new one that has c-clips. These use the stock L92 Rock Supports and they come with new rocker bolts.
The L92 Roller Tip Rockers will come out some time in the near future, I will try a set when they are available.
Stock L92 Rockers
![](http://i3.photobucket.com/albums/y80/aloysius66/IMG_0983.jpg)
![](http://i3.photobucket.com/albums/y80/aloysius66/IMG_0984.jpg)
![](http://i3.photobucket.com/albums/y80/aloysius66/IMG_0985.jpg)
Harland Sharp Modified L92 Rockers
![](http://i3.photobucket.com/albums/y80/aloysius66/IMG_0986.jpg)
![](http://i3.photobucket.com/albums/y80/aloysius66/IMG_0987.jpg)
![](http://i3.photobucket.com/albums/y80/aloysius66/IMG_0988.jpg)
L92 Heads with Harland Sharp Modified L92 Rockers Installed
Stock L92 Rockers
![](http://i3.photobucket.com/albums/y80/aloysius66/IMG_0991.jpg)
LS1Tech Sponsor
Since your in the testing stage have you thought of testing back/back the L92's against another head like AFR,ETP,or trickflow?
