Next stage of the build
FormerVendor
Originally Posted by Tootall
where are the rockers hitting the heads? . . . on the push rod side?
The only down side is that if we have to use 1.8 ratio for clearance I will need to have another cam ground as I have the cam here already and it was ground for the 1.7 ratio.
FormerVendor
Plans changed a little on the rockers. They will need to redesign the push rod cups in order to use the rockers on the L92 heads.
I have a set of the stock rockers ordered from Scoggin and Dickey along with the rocker supports and bolts. I am sending the stock rockers to Harland Sharp for the HS Modification. They change out the fulcrum so the needle bearing don't fall apart. I will post up pictures as soon as I get them back.
FormerVendor
Originally Posted by rpav
i am going to send mine in as well. just waiting for the new set to come in. do you know what they charge for this?
I have not been billed yet because of the change in plans. I have seen it on LS1Tech that they charge $250.00 to do it for you.
Originally Posted by 2005SSR6Speed
Did you get a set of his L92's also?
FormerVendor
I received the modified L92 Rockers back from Harland Sharp today. They remove the needle bearing and replace the pivot with a new one that has c-clips. These use the stock L92 Rock Supports and they come with new rocker bolts.
The L92 Roller Tip Rockers will come out some time in the near future, I will try a set when they are available.
Stock L92 Rockers
Harland Sharp Modified L92 Rockers
L92 Heads with Harland Sharp Modified L92 Rockers Installed
Stock L92 Rockers
LS1Tech Sponsor
Since your in the testing stage have you thought of testing back/back the L92's against another head like AFR,ETP,or trickflow?
