Next stage of the build
Old 10-13-2007, 09:02 PM
  #51
FormerVendor
leftcoast32's Avatar
Originally Posted by moregrip
good deal, glad it all worked out well for you
Thanks for everything. I will check on your Chrome Parts when I drop mine off this week. Be safe my friend!!
Old 10-17-2007, 08:34 PM
  #52
FormerVendor
I was able to install the L92 Heads with .052 Cometic MLS Gaskets today. Everything is torqued down with the ARP Head Studs and I checked the Pushrod lengths one more time before ordering. I will give Comp Cam a call for the Hardened Pushrods then I can button up the heads.
I used Unmilled Heads, .052 head gaskets, LEP Custom Ground Cam and the Harland Sharp Modified Stock Rockers and my pushrod length came out to 7.4 which is the stock length.
Old 10-17-2007, 09:08 PM
  #53
what a rush!
moregrip's Avatar
oh good deal, makes that an easy order
Old 10-18-2007, 02:23 PM
  #54
FormerVendor
Here are some pictures with the WCCH Stage 2 L92 Heads on awaiting the hardened pushrods that will be here Monday from Comp Cams.
Old 10-24-2007, 08:48 PM
  #55
FormerVendor
I received the MP122HH today for the build. I need to get the Intake Gaskets and set up the Injectors and Fuel Rails then get it on the engine. It is Over-Driven in the rear so we can make around 14-15 psi of Boost.
Old 10-24-2007, 10:21 PM
  #56
FormerVendor
Richard@WCCH's Avatar
That sure looks sweet Joe!! Very nice attention to detail. Thanks for posting up your progress of this build.
Richard
Old 10-24-2007, 10:23 PM
  #57
FormerVendor
Thanks, I cant wait until it is tuned to see how that much boost feels!
Old 10-25-2007, 10:08 AM
  #58
blownerator
BlownChevy's Avatar
Lookin Good Joe!
Old 10-25-2007, 10:43 AM
  #59
FormerVendor
Originally Posted by BlownChevy
Lookin Good Joe!
Thanks for all your help getting this put together for me!!!!
Old 10-26-2007, 07:41 PM
  #60
FormerVendor
I was able to get the intake gaskets in and test fit the manifold. I am waiting on a set of fuel rails from Michigan so I can install the injectors. Once I get the injectors and fuel rails installed I will do a final assembly of the top end. I am still waiting on the pulley's from Innovators West which will be here next week. The pictures are without the Inlet for the SuperCharger installed.
Quick Reply: Next stage of the build
