NNBS Lifted Burbn' Turbo Project
#22
10 Second Truck Club
Originally Posted by alex226;5104561
[URL=http://s37.photobucket.com/user/alexl226/media/turban/image_4.jpeg.html
[/URL]
Oil drain
Oil drain
#25
Formerly ScreamingL
ive installed 6 On3 turbos all 7665s and Ive gotten away with using just regular straight -10 fittings making sure everything has been clocked correctly, its a tight fit but they do fit
#26
I'm not against the 80e at all. I in fact agree it would ease my mind the most. Just wondering if anyone ran one of the black edition's in a heavy a** truck. The ability to simply pull mine out put that one is the only reason I ask. Got an event the truck needs to be at next month, crunched for time.
#30
And am I correct in thinking, I should change the input shaft on the T-Case to a 32 spline instead of doing the output shaft adapter kit that PATC sells (I believe makes the output shaft a 27 spline to mate up with the 60e t-case). But i would still require the "adapter" just not the output shaft?
