NNBS Lifted Burbn' Turbo Project
#52
The converter was recommended from circleD for my "mostly towing" application. It uses the stock 310mm 4L80e converter core with a billet cover and piston, plus some internal mods to handle the power and stall out around 2500-2600.
#55
Thanks. It's took awhile but ended up good. I ended up buying 3 different input shafts before we got the right one. I had a horrible grinding on decel and reverse. Got that all sorted out now. The converter is badass and so is the 80e.
I actually didn't use the crossmember I bought or the trans mount. And I have 2 other inputs shafts that would work on most of the transfer cases, ha. If anyone is interested in doing the swap that's pretty much everything you would need.
#56
If I ever get a NNBS Suburban, I plan on it looking like yours.
